0 Members and 1 Guest are viewing this topic. Read 6991 times.
I think you'd have a very very hard time blowing a speaker due to too much power. In order to do that you'd have to force feed a lot of juice (I mean a whole lot) into a speaker that isn't rated for anywhere near that much at insane volumes over a long period of time.
Steve, are you confirming what I just wrote: "power handling" = "maximum SPL (dB) that the speaker can produce"?In that case you should be able to take the efficiency of the speaker, factor in the power handling, and come up with a figure for max. dB at 1 meter (at a specific frequency). Is there such a calculation that can be made?
oneinthepipe, I also use a Marantz CD5001 and an imac as music source, I was comparing both run through the AVA insight DAC, I preferred the DAC to the direct from either the marantz or the squeezebox. The AVA DAC sound was clean, especially the high and mid range, regardless how much I increased the db, but without the DAC the sound was distorted at increased levels,the AVA DAC added a new dimension to listening to music. T
