0 Members and 1 Guest are viewing this topic. Read 10190 times.
I remember Paul Garner. Once you got him on the phone he never stopped talking. Very informed audioholic. Anyhow I bought my VSA GEN III HSE speakers from him about five years ago. Since then I've tried various speaker cables. I really can't tell any difference between expensive cables and regular 12gauge wire. Much better results with good electronics. Preamp. Amp. Cheers Charlie
We advice to connect the spadelugs direct and tight to the WBT on the VSA's.In this way you skip an other "dip" in the signalpath.
Hi Gavin,The pictures look very good.Q.We advice to connect the spadelugs direct and tight to the WBT on the VSA's.In this way you skip an other "dip" in the signalpath.Did you try this?Regards,Cor
Wow that's some setup Jack.
I'll have to think about it. I hate those darn spade lugs Wow that's some setup Jack. I've seen that picture before. Is Keith wanted by the law hence the fuzzing out? ..and the unavoidable addendum: or is he just on the Lamm?
That said, I've never heard a cable change that made a poor system sound good but I do hear cables that make a good system sound different. Yes there is a lot of BS out there in cable-land but tell me a business where that isn't at least partially the case? At the end of the day, if you want to find cable improvements, trust your ears and then figure out if the differences are positive and warrant the cost for you. As Gavin notes, cable auditions at home are invaluable.
