0 Members and 1 Guest are viewing this topic. Read 22933 times.
"what range are we testing for?"
I guess the question of "what range are we testing for?" arises.If we are testing bass traps, what level should we start with. I had thought I would just be putting the sealed servo sub in the room. But if we want the 500 hz range or something, I need to get a real set of speakers in there, so its going to involve more setup...-Tony
Right, and that's how the lowest mode is determined. Only half of a wave needs to fit to support resonance...
Liquid Nails helps make a good, airtight seal.
When I go to home depot to get the insulation to stuff in the tubes, what should I get, and should I really be firmly packing it in, to be properly made?
ASC makes what they call a MATT (music articulation test tone) that you can find on Stereophile test CD #2. This is an excellent signal for checking the effects of room issues (and treatments). Listening to the MATT via headphones, then via your speakers (with and without treatments or with treatment A, then treatment B) will be an education in itself. The headphones of course, will give you the tone without room effects. After hearing this, you'll find it a lot easier to hear what the room/treatments do in between the pulses of the tone.
There was a link to this test tone to download, and some other tutorials on how it should be used. I don't think its something that I could really measure. I will use the signals available on the room eq wizard software, periodic pink noise, sinewave plots, and waterfall.-Tonyhttp://www.acousticsciences.com/matt.htm
just got back from the store this evening with 2 bales of unfaced r-13(116 sq feet each). Althought I think its packed a lot tighter than its going to be in the tube
If you haven't already opened the plastic bags, please test those first. Leave them as they are, sealed in the bags, and stand them up leaning into the corners.--Ethan
Should I take off the closet doors?
Yeah, this is why you really need to test about eight panels to see a clear trend. If you change the displays to show up to 300 Hz you'll see more affect.What's the difference in trap placement between Image 4 and Image 5?--Ethan
