Audio/Video Gear and Systems
The HiRez Music Circle
ted_b
HiRez converters: optical to coax, USB to coax needs 24/96 resolution
0 Members and 1 Guest are viewing this topic. Read 2159 times.
EDS_
17 Oct 2009, 04:09 am »
Need a high quality version of each converter. The HagUSB to coax looks interesting for the later. Any thoughts?
EDS_
Re: HiRez converters: optical to coax, USB to coax needs 24/96 resolution
17 Oct 2009, 03:31 pm »
Throw a brother a bone will you?
WGH
Volunteer
Mesquite Salk Speakers
Reply #2 on:
17 Oct 2009, 04:01 pm »
The HagUSB will only convert 16-bit 32 kHz, 44.1kHz, and 48 kHz so I would not classify it as a HiRez device although it is excellent for standard redbook CD's.
Wayne
TomS
Just relax, ok?
Reply #3 on:
17 Oct 2009, 04:03 pm »
This USB-S/PDIF is supposedly up to 24/192
http://www.audiocircle.com/index.php?topic=72468.0
EDS_
Reply #4 on:
17 Oct 2009, 05:24 pm »
Thanks all.
Right now I'm running optical into a generic (~$14 IIRC) toslink to coax converter than seems to be sending 96/24 info. through. The SQ is different for sure switching the Mac Audio/Midi setting from 16/44.1 to 24/96 - although I'm not really sure it sounds better. Need to listen longer.
Tool - "Hooker With a Penis"
ted_b
