SPEAKERS AND HORN LOADED
0 Members and 1 Guest are viewing this topic. Read 1471 times.
drummermitchell
« on: 14 Oct 2009, 12:14 am »
ANY BODY HAVE EXPERIENCE WITH HORN LOADED SPEAKERS AND COMPARE THEM WITH REGULAR TWEETER LOADED SPEAKERS
wOULD THE HIGHS BE MORE EXTENDED ORRRRRRRRR,WAY SWEETER THAN.....
  • The Demo is Everything!
    • http://www.bryston.com
Re: SPEAKERS AND HORN LOADED
« Reply #1 on: 14 Oct 2009, 12:21 am »
Hi Don,
Remember as well their are basically two types of Horn speakers:
1. Compression driver horn speakers (Ex JBL)
2. Waveguide type horn speakers (Ex Avant Gard)
james
drummermitchell
« Reply #2 on: 14 Oct 2009, 12:40 am »
Thanks james,compression drivers.I wish ther was some here to check.
If i can step up,then that's what I'll do.would they be to trebley in a small room.
« Reply #3 on: 14 Oct 2009, 01:22 am »
I do not think horn speakers would be too bright.  The advantage of a horn is that it directs the sound towards you and there tends to be much less splash off the listening room sidewalls, ceiling etc. which means less brightness not more.
james
drummermitchell
« Reply #4 on: 14 Oct 2009, 02:04 am »
I kinda figured that,thanks James.
