My Philips SACD1000 multi-channel, Stan Warren recipe cables, McCormack MAP-1 multi-channel preamp & the room & treatments were constant during the changes below. The cables have beat $800 Analysis Plus & another $600 interconnect. The preamp was preferred to several much more expensive including a $12k Audio Note & a $7500 Jadis. The preamp has an AMR (ambience recovery mode) that converts 2ch into 5.1 multi-channel, purely in the analog domain, with better audible results than any DSP technology I know of. The preamp improves by about 20-30% with shorting RCA plugs inserted into every unused jack (FYI the shorting plugs allow a little sound to pass through when the preamp is muted). All gear must be burned in fully.
The 2ch system had a $5800pr of VMPS RM40s including the $1200 TRT capacitor upgrade, powered by a $5500pr of Ampzilla 2000 mono blocs.
The 3.1 system (to be 5.1) included: VMPS 626R (L-R front) & VMPS LRC (center) powered by McCormack 3ch DNA-HT3, VMPS Larger Sub w/upgrades powered by the Parts Express 1000W Subwoofer Amp/xo/eq.
Whether listening to multi-channel SACD or 2ch converted in the analog domain into 3.1, the MC system produced a huge increase in enjoyment. An added bonus is the huge improvement in sound for video viewing. The kicker is about $5000 MSRP saved & much shorter speakers.
If you have discounted multi-channel, I recommend auditioning a properly burned in MAP-1 system, preferably with a matching McCormack amp (their appears to be an incredible synergy between the two). I intend to get the 5ch McCormack amp & a pair of surrounds to finish the system.
IMO 2ch is dead, dead, dead, & I’ll personally never consider it for music enjoyment again. If you audition a properly tuned system with the MAP-1, & switch its ARM in & out with your best 2ch sources, you might agree.
It's only my opinion, but that's my story & I'm sticking to it.
