Break in Period for 4b sst2 ?
0 Members and 1 Guest are viewing this topic. Read 2503 times.
robb
« on: 12 Oct 2009, 03:49 am »
Hello
Received my new Bryston 4b sst2 the other day.  Was wondering what the typical break in time is, and what characteristics usually change over that period? ie, what can I expect in improvement.
Thanks for any advice and info
rob
Levi
Re: Break in Period for 4b sst2 ?
« Reply #1 on: 12 Oct 2009, 06:03 am »
Hey Rob,
All Bryston amps are broken-in in the factory so that any anomalies can easily identified.  Needless to say, there may or may not have any change in the characteristics in sound 95% of the time.  Enjoy it already!  :)
--Levi
Mag
« Reply #2 on: 12 Oct 2009, 01:30 pm »
IMO whenever introducing equipment that changes the sound even if marginal. It takes the brain about 2 weeks or 50 hours to learn to interpret the new information. There is no break-in period for equipment unless you plug the unit in and its still cold from being on the UPS truck.
1ZIP
« Reply #3 on: 12 Oct 2009, 05:51 pm »
Rob:
As you probably know arguments have raged over the burn in" issue.  Bryston runs their gear for 100 hrs before shipping, mostly, I gather, to insure that the units meet or exceeds specs and operates as advertised.   I don't know if that is because a typical (not necessarily Bryston) piece of electronic eq. failure rate is highest in the first 100 hours or if in fact there is something to the "burn in" issue.  If memory serves me correctly James once said that another 50+ hours beyond what the engineers want is better.
However, I doubt if your going to see much change, but some have noted a difference over time.  Whether that's real or imagined starts the argument all over again.  But, from personnel experience, I can tell you this, I had a tuner restored and completely recapped with matching Blackgates. After 100+ hours the sound had changed significantly and it wasn't just my ears but the ears of  several who had heard it immediately after restoration and then again 150+ hours later.  So, at least in some instances I believe that the "burn in" issue has some validity.
But back to Bryston, I have not noticed any change in my 4 sq. over time, if you note any change it will only be an improvement on an already great sounding piece of gear.
Enjoy!
danman
« Reply #4 on: 12 Oct 2009, 07:27 pm »
I have not noticed any change either only when I tweek other items.
Biggest change was the addition of a turntable!!!!
robb
« Reply #5 on: 15 Oct 2009, 03:16 am »
Thanks.  And I have heard opinions ranging from 0 hours to 200 hours for break in!
I guess with Bryston the sound is so good, I don't have to worry about break-in characteristics.
Rob
vegasdave
« Reply #6 on: 15 Oct 2009, 07:59 pm »
I will say it sounds best when it's left on all the time, imo.
