Cornet 2 photo s
0 Members and 1 Guest are viewing this topic. Read 1830 times.
shedman
Cornet 2 photo s
« on: 11 Oct 2009, 08:08 pm »
When i first built my cornet it was in a hammond chassis it looked bad ,after reading lots of old posts i decided to upgrade the parts as well .My woodwork and metalwork skills are far better than my electrical .I am very happy with the looks and sound
Mr Ed
Re: Cornet 2 photo s
« Reply #1 on: 13 Oct 2009, 03:22 am »
If it sounds as good as it looks your in for a treat! :thumb:
What wood, and how is it finished ?
Ed
shedman
« Reply #2 on: 15 Oct 2009, 08:36 am »
Hi  Ash base then veneered with Macassar Ebony.Finish = sanding sealer 3 coats ,Danish oil 3 coats ,rubbing down between each coat up to 1000 grit.No wax. Plan to change chassis on my st35 amp (clone) to same ,matching pair should look good  cheers
satai74
« Reply #3 on: 17 Oct 2009, 08:02 pm »
What did you use as signal capasitators?
You using 47uF for the rectifier tube?
I thing for 5y3 tube u should use 10uF, or am i wrong?
Atleast it says so on 5y3gt datasheets.
But on hagermans it says to put 47uF, which to my knowledge shortertens the life on rectifiertube.
Correct me if i am wrong
Edit: and this looks stunning!  :thumb: :thumb:
