Another Apple TV question
0 Members and 1 Guest are viewing this topic. Read 1198 times.
Art_Chicago
« on: 11 Oct 2009, 03:37 am »
Can one connect an external drive to Apple TV through USB and use a laptop to run itunes?
Crimson
Re: Another Apple TV question
« Reply #1 on: 11 Oct 2009, 11:46 am »
Not officially.  :wink:
There are hacks out there that allow you to do so, but I don't see the need as you can connect to a remote library through iTunes, and then stream to the ATV.
Art_Chicago
« Reply #2 on: 11 Oct 2009, 01:54 pm »
thank you, Crimson, but I am still confused a bit. By remote library you mean the external drive connected to the laptop using a cable of wi-fi? I'd like to avoid cables so I can use the laptop while streaming to the ATV. Just thinking that 160Gb of ATV won't last forever. Thanx!
Crimson
« Reply #3 on: 12 Oct 2009, 11:34 pm »
By remote library I mean either streaming to the ATV from a remote machine, or having the ATV access a library on a remote machine. Either wifi or wired works. Try it out.
