0 Members and 1 Guest are viewing this topic. Read 8561 times.
It's best to kill at at the sources rather than at the amp.
So then plug the appliance into the surge device? But if it's from the furnace and the motor is 240V that might be more difficult without a solution at the breaker box.
Maybe this would help.http://www.fruitridgetools.com/storefrontprofiles/processfeed.aspx?sfid=136763&i=238053403&mpid=8171&dfid=1
Power Req. 120VAC 50Hz / 240VAC 50Hz and it has a 3 amp slow blow fuse (I am clueless if that means the amp only draws 3 amps. . .I'm pretty ignorant when it comes to that kinda stuff)
However. . .the conditioner specs I see don't list the max watts. (See above) Here are more detailed specs on another one I'm looking into (many irrelevant to the issue at hand). Can you tell from this if it would be able to handle my amp?Current Rating: 20 Amps
