Audio Pornography part II -- the RM/X
0 Members and 1 Guest are viewing this topic. Read 3517 times.
ekovalsky
« on: 6 Jan 2004, 01:14 am »
These speakers are heavy.  A lot heavier than the RM-40's which I recently packed up.  Hoisting them from laying on the floor to upright felt about like doing a 335 lb squat which is as much as I do in the gym for fear of injury.
Cabinets are obviously built to a totally different level of quality than the RM-40.  They are incredibly solid and dead.  The Wilson Grand SLAMMEs (which a friend owns) have nothing on these.
Listening was a bit delayed by a problem with my brand new JRDG 302/4.  Turns out one of the four output channels is not functioning.  Right now I have the right speaker biamped and the left speaker biwired.  I'll switch both to biwiring later.  Not happy about having a very expensive and brand new amp malfunction, but when I called JRDG I was transferred to Jeff Rowland himself.  He was incredibly nice and suggested that I bring the amp up to to him at CES so he can fix it himself !  He's bringing his tools and spare parts.  He thinks one of the four ICEpower modules or its power regular is bad.   The parts inside the amp are modular so I probably could fix it myself, but since he offered I'll let him do the dirty work.
First listen of the RM-40's "out of the box" -- dramatically better than the RM-40's.  There is no mistaking the true line array of midrange panels.  The bass sounds better integrated and much more powerful.  I definitely will not be needing subwoofers.  My wife said they were "cleaner" and I would have to agree.  Even without any tuning I was hearing the best reproduced sound I've ever heard.
The RM/x does have some unfair advantages over the 40's, specifically a decent amount of room treatment added after the old speakers shipped out and a much better amp to drive them.  Also the preamp and one set of interconnects has been removed from the signal chain (I'm driving the amp directly from the dCs Elgar Plus with its digital volume contro).   But I am confident the RM/X themselves are in a different class than the RM-40, which they should be given the difference in cost and lead time.  I think Julian's prior comments about the differences between the RM-40 and RM-X were right on.
I've removed a tiny pea-size dab of putty from each passive and probably will hold off doing any more fine tuning for several weeks while they continue their break in.
There is still a lot of work to do in the media room, including a 4' x 6' piece of foam going in between the speakers on the front wall, some will be cut away to accomodate a 60" plasma TV.  Also drapery fabric will be hung on the walls, concealing the fiberglass panels and hiding speaker wires for the surrounds in the future.
New cables are also on the way -- two pairs of speaker cable and one balanced interconnect (Pursang from Argent/Roomlens).  May try some other cables too, including Ridge Street Poiema and VeraStarr Silver Reference.
All for now.  Enjoy the pictures!
The outer sarcophagus.  A very, very big box.
Hmmm... anyone need a coffin for cheap?
The mummy being removed from the inner sarcophagus.  That's Brutus helping me out.
The ribbon array #1
The ribbon array #2
Eye of the cyclops  :lol:
12" Megawoofers kicks serious ass!
Looks fine without the flash.  Will try to clean up with some distilled water and a microfiber cloth.  The hex nut, which may not be present on the other pairs of RM/x, locks the head in position.
Top pair of posts bypasses the passive filter on the woofers to allow use of an electronic crossover
PeteG
« Reply #1 on: 6 Jan 2004, 01:59 am »
Eric,
You have one awesome system. :o
jgubman
« Reply #2 on: 6 Jan 2004, 02:10 am »
Wow, looks great! Congrats again.
What about the Walnut inlay though? Is it a subtle effect or does it just not photograph well?
ekovalsky
« Reply #3 on: 6 Jan 2004, 02:24 am »
Long story...  speakers are piano black.
Quote from: jgubman
jgubman
« Reply #4 on: 6 Jan 2004, 02:26 am »
oh, sorry. Well, they look great regardless.
And you made your Acoustic Zen cables stop glowing! They must be scared to try and show off around the new speakers...
rkapadia@ROOP
« Reply #5 on: 6 Jan 2004, 02:43 pm »
Eric,
Congratulations on the RM/X - give them a 100 hours, and you'll probably have forgotten what the RM40's sound like :).
Redbone
« Reply #6 on: 6 Jan 2004, 02:45 pm »
Very, very nice speakers and system.  Eric, what are the third set of terminals, the top most ones, for ?
azryan
« Reply #7 on: 6 Jan 2004, 06:30 pm »
Awesome!
I'm guessing having them that close to the wall is giving you a lot of that bass compared to the 40's being so far from the walls as I heard 'em.
Any sense of depth diff. being that close to the wall either?
Should be even better whatever it is when you put up that panel between the speakers.
But putting that large glass Plasma set between them... I hope you'll have something to put in front of that bad reflecting glass when you're just listening to music.
ekovalsky
« Reply #8 on: 6 Jan 2004, 11:04 pm »
Quote from: azryan
Awesome!
I had the 40's in basically the same position before they were sold.  When you were here they were placed far out from the short wall instead of closer to the long wall.  I basically followed Dunlavy's setup method which works well in my room.  Dunlavy is gone, but you can get his setup instructions (when the Wayback machine is functioning) at:
http://web.archive.org/web/20020609171104/www.dunlavyaudio.com/audio_files/listening.html
I placed my room layout drawing on the gallery here:
http://www.audiocircle.com/index.php?action=gallery;area=browse;album=164
I think it is worth mentioning that the larger VMPS systems work very well in small to medium size listening rooms.   I've heard the ST3 SRE sound very good in a fairly small room, and the huge RM/X is causing no trouble in my room.  The multiple bass paths prevent severe room nodes.  I would expect much more troubles with a single woofer system or subs.
Depth has always been kind of tough for me.  I definitely can hear some sounds which seem to arise from behind the wall, so I think that is a good sign.  Foam to place in between the speakers should be here any day, I agree that is necessary!  It's a 4' x 6' sheet, 3" thick.
There will be drapery fabric hung over the walls which will conceal the Acoustic First panels, the foam, the plasma TV and the glass sliding doors through which the room is entered.  The curtains will be fixed, except for around the door and plasma TV where they will be on slides.  This is the interior decorator's idea -- had I known we were going to do this I would have just ordered foam for the whole room instead of the fiberglass panels, since foam is about 1/2 the price  :xhttp://
ekovalsky
« Reply #9 on: 6 Jan 2004, 11:30 pm »
Quote from: Redbone
Those are an extra pair of terminals for the bass which bypass the internal passive crossover.   For use with Marchand, Krell KBX, TacT, etc...
ARAM
gorgeous
« Reply #10 on: 7 Jan 2004, 01:45 am »
Gorgeous  speakers..With  the  USA $  falling  at  record  levels   I  am  just  rubbing  my  hands  for  my  next  speaker  upgrade :D
