Not using mono switch in Cornet
0 Members and 1 Guest are viewing this topic. Read 1353 times.
penance
« on: 5 Oct 2009, 02:28 pm »
If i dont want the mono/stereo switch in my cornet where should i put the bypass wire?
Theo
Re: Not using mono switch in Cornet
« Reply #1 on: 5 Oct 2009, 06:53 pm »
No wiring or bypassing required.  You simply don't install the mono switch.
Bill Epstein
« Reply #2 on: 6 Oct 2009, 01:00 am »
But you should.
My latest build is the first with the mono switch and mono albums really do sound better in......mono :thumb:
penance
« Reply #3 on: 8 Oct 2009, 07:13 pm »
Thanks Guys, thats nice and simple.
Bill, will probably install switch when it goes in its final chassis. At the moments tho it is in a cheap box for testing, well will be as soon as funds allow. Damn motorbike got in the way and swollowed half the bank ballance....
