0 Members and 1 Guest are viewing this topic. Read 20223 times.
I think it important to consider that USB is currently popular in DACs primarily because of the opportunities for commerce (the ubiquity of this type of port, designed for the purpose of providing an inexpensive means of connecting a mouse or keyboard).I cannot think of a single designer who, given carte blanche to create the best converters they are able to, would deliberately use USB as a means of transmitting or receiving digital audio (or video).In my experience, having had the good fortune to audition dozens of contenders, both pro and "audiophile", there is not a single example in the very best performing class of these devices where USB is part of the picture. (There are one or two in the "very good" class that offer USB as one of the options. I would suggest auditioning one of these units and comparing the USB option with one of the others. That will tell you all you need to know and the listener can draw their own conclusions.)
...And I would prefer to extract audio from a computer via Firewire rather than S/PDIF from a soundcard. Steve
I cannot think of a single designer who, given carte blanche to create the best converters they are able to, would deliberately use USB as a means of transmitting or receiving digital audio.
I think it is always a good idea to keep the as much of the audio circuitry outside of the computer as possible.
Then why not educate yourself regarding Asynchronous transfer mode?
A fine unit to be sure.While it requires a Mac to set up, uses non-audiophile type connectors (DB25) and has a bit of a learning curve, when it comes to the bottom line: how it sounds with music, I've heard nothing so far that touches the ULN-8 from Metric Halo.Aside from being the best DAC I've heard (I've also compared it with my previous favorite, the Pacific Microsonics, as well as units from Meitner, Prism, Weiss, Cranesong, Hedd, Lynx, Mytek, Benchmark and a dozen other "contenders"), it happens to work standalone, has a digitally controlled analog volume control and built in headphone amp (with separate DAC).It is an 8 channel device and just happens to include 8 channels of A-D (the best I've heard to date), 8 mic preamps (ditto), the best recorder I've heard regardless of format or price (in the included Record Panel software), the best summing mixer I've heard (80-bit! in the included Console software) and more dsp horsepower than I will foreseeably use. (Oh, and if you like tubes -or FETs or transformers, the software allows a selection of quite credible emulations - selectable of course.)This is really designed as a pro unit but at $6k, it costs considerably less than a lot of audiophile "jewelry" that (to my ears) it leaves in the sonic dust.Just my perspective.Best regards,Barrywww.soundkeeperrecordings.comwww.barrydiamentaudio.com
If Metric Halo came out with a 2 channel version of ULN-8, with RCA & XLR outputs and a remote, I think a lotcomputer audiophile would buy it. Yes, I know about the ULN-2, but it's limited to 24/96.
I'm well aware of Asynchronous transfer mode and what USB can (and can not) do.Just my perspective.
Your post made it sound like the opposite. I appreciate your perspective. The ubiquity of this type of port (USB), your words, is one of the features that attracted me to the Ayre DAC. For me it was a seamless progression to add a USB DAC into my system. I bought a Mac Mini then the Ayre product. No Lynx card, no SPDIF converter. Kirk
srb,With respect; I think it's a mistake to claim that only the Ayre and Wavelength DACs, using Rankin's software, can sound great via USB. Lot's of NOS USB DACs sound great as do a large number of OS/US USB DACs.
...In the studio, Firewire is more suited to transfering audio data. The way in which USB transfers audio packets does not lend itself to multi-channel work. In fact, Firewire 400 can't often keep pace and Firewire 800 has become the standard. Steve
