Gainclone project, model "monster"
0 Members and 1 Guest are viewing this topic. Read 5053 times.
peranders
« on: 5 Jan 2004, 11:28 am »
What do you think of my ultra universal Gainclone project?
I have made partslists for common 6 different models.
1 Non-inverting buffer, Non-inverting LM3886, DC-servo
2 Non-inverting buffer, Inverting LM3886, DC-servo
3 Inverting buffer, Non-inverting LM3886, DC-servo
4 Inverting buffer, Inverting LM3886, DC-servo
5 No buffer, Non-inverting LM3886, No DC-servo
6 No buffer, Inverting LM3886, No DC-servo
*  Inverting or non-inverting LM3886, can be chosen
* Inverting or non-inverting input buffer, with or without gain, can be chosen
* Feedback network which can satisfy everyone, full gain at DC or gain of 1 using a capacitor in the feedback
* With or without DC-servo for both inverting or non-inverting LM3886, can be chosen
* Output filter, L//R, small handwound inductor plus a resistor.
* Inputfilter, lowpass and also highpass to block incoming DC-signals. You could also skip the filters if you want to. I recommend though to use a high frequency lowpass filter.
* Mute, the LM3886 is "dead" for a short time at power up, can be chosen.
* Bridge connection and the LM3886 can operate in inverting or non-inverting mode, can be chosen.
* Pcb for 2 separate channels, stereo, or one channel in bridge connection. It's possible to change mode easily with help from a jumper.
* Power supply be on the pcb with sufficient amount of smoothing capacitance.
* Stabilized power supply for the buffers. +-12 V is chosen (can easily be changed) so the amazing AD8620 can be used.
http://home8.swipnet.se/~w-80046/hifi_files/qrp/qrp01r0schema_p1.pdf
http://home8.swipnet.se/~w-80046/hifi_files/qrp/qrp01r0schema_p2.pdf
http://home8.swipnet.se/~w-80046/hifi_files/qrp/qrp01r0schema_p3.pdf
http://home.swipnet.se/~w-50719/hifi/gainclone
....  but there is a small problem! The amp doesn't exist in the real world, not yet. But there is a way to get hold of pcb's. This project is a t hobby level for me and it costs money, but it takes also time, which I have not much of. 3-5 people is needed to help me in building and debugging the pcb. When I write this I have two persons which is interested. Those who help me get also rewarded.
JohnR
« Reply #1 on: 5 Jan 2004, 02:19 pm »
Hi peranders, I'm kinda curious, why do you want to have so many different configurations?
BTW, what is the DC offset without the servo? Can't be very high surely - ?
peranders
« Reply #2 on: 5 Jan 2004, 03:19 pm »
I wanted to make the pcb super universal, that's the reason.
The DC offset can be rather high in some circumstances but if you want the lowest noise possible it's a good thing to use a servo. I have read rather much about offset problems so I made the DC-servo option just to eliminate the offset completely and also make more room for a wider choice of component values.
peranders
« Reply #3 on: 19 Jan 2004, 09:08 am »
I have ordered pcb's today. :D
peranders
« Reply #4 on: 28 Jan 2004, 09:14 am »
What do you think?
Ferdi
« Reply #5 on: 28 Jan 2004, 11:06 pm »
Looks great!
I am really keen to hear your experiences. I seem to remember from most discussions I have read that physical proximity of parts is a main reason for the good performance of Gainclones. Using a PCB goes against that to an extent.
Good luck!
peranders
« Reply #6 on: 28 Jan 2004, 11:15 pm »
Have you checked how far away many parts are? It's always a good thing to keep amplifier compact.
Please notice that the picture is changed, took the wrong one...
peranders
« Reply #7 on: 5 Feb 2004, 10:10 am »
I have changed the picture above. What do you think now?
JohnR
« Reply #8 on: 5 Feb 2004, 10:59 am »
Looks good!
How does it sound?
peranders
« Reply #9 on: 5 Feb 2004, 11:40 am »
I don't know really, good I hope. I have very little spare time at the moment so I'll have to wait a while.
peranders
« Reply #10 on: 13 Feb 2004, 05:11 pm »
My QRP-01 is alive!!!! Seems to work very nicely so far without heatsink. Output offset 115 uV, Left channel, 10 uV!! Right channel.
