Different tube options for Cayin 860 amp
0 Members and 1 Guest are viewing this topic. Read 2143 times.
ctviggen
« on: 30 Sep 2009, 11:12 am »
I have a Cayin 860 amp that has the following tubes:
4 6550EH tubes in the main amp section
12AX7, 12AU7, and 6N6 in the preamp section
Does anyone have recommendations on which tubes (if any) I can change, and suitable replacements for these tubes?
Thank you!
Balle Clorin
Re: Different tube options for Cayin 860 amp
« Reply #1 on: 24 Oct 2009, 04:51 pm »
5751 for the 12AX7 give lower gain and less noise form preamp it that is a problem.
12AU7 i have replaced with 5814.
I got some russian 6N6 (6H6N) from ebay.
You may try KT88 for the 6550. I run New Re-issue  tungsol 6550
http://www.tubedepot.com/5751.html
Best regards Balle
kenreau
« Reply #2 on: 24 Oct 2009, 05:40 pm »
I had the Cayin 860's for a couple of years.  I made a ton of upgrades to the caps, resistors, wires, parts, etc.  They are exceptional amps for the money with the right speakers.  You can do a search here to read more on my upgrades if interested.
I used NOS Mullard Blackburn tubes at the 12AX and 12AU locations, RCA Cleartops at 6H6N and the new/reissued Mullards octet matched set for the EL34s.  The upgraded tubes made a nice improvement.
« Last Edit: 26 Oct 2009, 04:26 am by kenreau »
