**SOLD**JOLIDA JD 202A Integrated 40+40 Watts RMS Ultra Linear ? Class AB1
0 Members and 1 Guest are viewing this topic. Read 4471 times.
Big Red Machine
$500 + shipping
Mullard and Electro-Harmonix upgrade tubes included with the stock tubes.
Also have a brand new quad of Gold Lion KT77's for $175 more.
SPECIFICATIONS
Maximum Power Output: 60 W per channel at 8 ohms, 1KHz
Rated Output Power: 40 W per channel at 8 ohms, 30Hz to 80KHz
Frequency Response: (at 1 watt into 8 ohms) 7Hz to 140KHz + 3dB; 0dB at 1KHz
Bandwidth: 17Hz to 140KHz + 3dB; 0dB = 40 W 1KHz, 8 ohms
Distortion THD + N: Less than 1% at 30W output, 40Hz to 14KHz, 8 ohms
Circuit Type: Ultra Linear, Class AB1
Input Impedance: 100Kohms
Input Sensitivity: Max. 350mV at 1KHz for 40 watt output
Output Impedance: 4 ohms and 8 ohms
Negative Feedback: Less than 9 dB
Noise and Hum: 80dB below rated output.
Tube Complement: 2 matched pairs (4) of 6CA7/EL34 power output; 2 pcs. 12AX7A pre-amplifier, 2 pcs. 12AT7 power drivers.
Power Requirements: 110V-120 VAC 60Hz 120 watts-standby, 300 watts maximum (220 VAC 50Hz option).
Dimensions: 12.5 inches (30 cm) wide by 12 inches (31 cm) deep by 8.25 inches (21 cm) high.
Weight: 28 pounds (13 Kg) net, approximately 32 pounds (15 Kg) packaged.
Warranty: One year limited parts and labor. Six months or 500 hours whichever comes first on Jolida Tubes.
Bias Settings: 40 millivolts + 4 mV
Fuse: 110-120 VAC, 6.3 Fast Blo; 200-240 VAC, 3 Amp Fast Blo
« Last Edit: 22 Oct 2009, 07:27 pm by Big Red Machine »
Bob in St. Louis
This is a great little amp. Built like a tank.
I've got the same exact unit that runs a two channel rig, as well as a home theater system. I've never "wanted" for more headroom or more watts, a real power house it is. Have never noticed it struggle, strain or protest when I get silly with the SPL. I'm using it to run a pair of 96dB coaxials with passive crossovers, but have no doubt it could power much less efficient drivers without a problem.
Honestly, I linked a buddy (who really needs this amp) to this sale, but he's out of money.  :(
Good luck on the sale BRM. Nice unit you've got there.
If I had the money, I'd buy it to start a system in another room.
Just because I like it so much.  aa
Oh....And there are plenty of mod available for those that like to tweak.  :wink:
Bob
Big Red Machine
I really love this thing.  It does have lots of power at 40 wpc rating.  The KT77's really make it sing as well.  I'm still a little hesitant to make the change but I have a very well respected tube pre coming as part of my pre amp sale and an integrated will be redundant.
Big Red Machine
bump
Big Red Machine
bump
Big Red Machine
Now on Audiogon.
Big Red Machine
bump.  nice sounding integrated unit folks.  Very ballsy.
