Ever try this?
0 Members and 1 Guest are viewing this topic. Read 1235 times.
danman
Ever try this?
« on: 27 Sep 2009, 01:37 am »
http://www.6moons.com/audioreviews/zero/zero.html
Interesting concept but does it work?
Robert D
Re: Ever try this?
« Reply #1 on: 29 Sep 2009, 12:48 am »
danman
What will it do
Do you Know
Robert
95Dyna
Re: Ever try this?
« Reply #2 on: 29 Sep 2009, 01:45 pm »
Isn't this the same concept McIntosh employs in the design of its solid state amps?  They all have on board autoformers that do impedence matching with 2, 4 and 8 ohm taps.  This product appears to do the matching up to 16 ohms but how many speakers are there with nominal impedences of over 8 ohms?  The end result of impedence matching is that the power output ratings remain the same regardless of the impedence the amp encounters.
