Other Stuff
Archived Manufacturer Circles
NuForce
Rel Sub
Rel Sub
0 Members and 1 Guest are viewing this topic. Read 1299 times.
bd13
Newbie
Rel Sub
25 Sep 2009, 07:55 am »
Is anybody using a Rel sub with the mch amp and if so how are you hooking it up
I want to use the high level connection is it possible
rustydoglim
Industry Contributor
ยป
Re: Rel Sub
29 Sep 2009, 08:38 am »
There is a cable you need to buy from Rel distributor. I heard some customer in Northern California with MCH has some issue with this cable but I am not very sure. May be you're the same person with this problem. Check with
[email protected]
Other Stuff
NuForce
Rel Sub
