[URGENT] Nuforce Icon Problem with Snow Leopard
0 Members and 1 Guest are viewing this topic. Read 2758 times.
anzo
« on: 24 Sep 2009, 10:04 pm »
I just upgraded to Snow Leopard for my MBP.
And notice my S-1 sounds weird and missing some of the sounds that i used to hear from songs.
After some testing, I notice the right channel is missing when i do a left-right panning for some songs. I hear nothing when I pan all the way to the right.
So should I seek help from Apple forum? or is there any work around or driver fixes that i can do?
anzo
Re: [URGENT] Nuforce Icon Problem with Snow Leopard
« Reply #1 on: 24 Sep 2009, 10:49 pm »
PS....or both speakers are outputing left channel... i'm not sure
all i know it's right is missing
and i already tried on another windows computer, i can confirm it's a OS/drivers problem
anzo
« Reply #2 on: 25 Sep 2009, 05:24 pm »
for ppl who use Snow Leopard
please try
http://www.audiocheck.net/audiotests_stereo.php
luxmann
« Reply #3 on: 26 Sep 2009, 01:26 am »
Hi,
My iMAC is OK with Snow Leopard and icon+S1.
Levi
« Reply #4 on: 26 Sep 2009, 01:59 am »
If your computer is working prior to Snow Leopard upgrade.  I would reinstall the old 10.4.x OS.  That should fix it.
Good luck,
--Levi
Picker
« Reply #5 on: 3 Oct 2009, 05:39 am »
My Icon works fine with Snow Leopard on a mac pro.
look at your apple -> system pref -> sound -> output
Make sure the USB Audio DAC is selected
Balance is in the center
Output vol is max
I put itunes vol at 80% so I can here system sounds
and change the icon vol depending how good the song is.
http://www.pandora.com/ does 192kbs tracks now.
http://www.bitcartel.com/pandorajam/
will put those tracks with images into itunes
