Help At Work
0 Members and 1 Guest are viewing this topic. Read 2509 times.
DMurphy
    • SalkSound
Help At Work
« on: 24 Sep 2009, 02:55 pm »
Please excuse the off-topic post, but you guys seem really into amplifiers for home theater, and I'm working on a project here at the Federal Trade Commssion that could be affected by the answer to the question I'm going to ask.  Are any of you aware of a HT receiver or multichannel separate amplifier that does not have the same power output (however measured) for the center and/or surround channels as for the main left and right channels?  Like maybe there are cheaper in-a-box systems that would have less power for the surrounds? Or maybe there are some high end or even popular units that have a different spec for the center or surrounds?  Thanks for any help you can give me.    Dennis
Big Red Machine
Re: Help At Work
« Reply #1 on: 24 Sep 2009, 04:00 pm »
Dennis, the Wyred multichannel amps come in varying wattages and many Adcom amps also.  Those are just off the top of my head.
A random grab:  http://www.wyred4sound.com/webapps/site/74030/117839/shopping/shopping-view.html?pid=332928&b_id=&find_groupid=18048
Other brands do this with the added capability of bridging some channels so you get a 2, 3, 4 or 5 channel amp from a 7 channel amp.  Lexicon has done it and I think Theta does as well.
Nuance
Re: Help At Work
« Reply #2 on: 24 Sep 2009, 04:17 pm »
Dennis, the Emotiva LPA-1 has a different wattage rating for the rear(s):
Configurable power output as follows:
125 watts/8 ohms x 6 channels or 125 watts/8 ohms x 5 channels plus 2 x 50 watts/8 ohms x 2 channels
Dennis, are you able to share what project you're working on?
Re: Help At Work
« Reply #3 on: 24 Sep 2009, 04:20 pm »
Carver av405 = 5-Channel Home Theatre Amp - 100W Left/Right, 110W Center, 50W Rear.
Many of the early ht amps when dolby pro-logic came out had unequal power to the 5 channels.
rcandiog
Re: Help At Work
« Reply #4 on: 24 Sep 2009, 07:32 pm »
Yamaha receivers have done this for quite a while.  Their old RX-V2092 was 100w per channel for the fronts and surrounds with 25w per channel for the effects speakers.  In their current lineup, the RX-Z11 is 140W x 7 + 50W x 4.
Rob
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
Re: Help At Work
« Reply #5 on: 24 Sep 2009, 07:45 pm »
Dennis:
Is this advertised power?  This is a different question, I assume, than about a multi-channel receiver that is advertised @ 200 watts, but when tested, the amplifier only produces 200 watts per channel into one or two channels rather than the entirety of channels?
« Last Edit: 25 Sep 2009, 01:38 am by oneinthepipe »
Srgtfury
Re: Help At Work
« Reply #6 on: 24 Sep 2009, 09:45 pm »
With the Post # 666 and the FTC aligning, it probably involves some really deep passages.
Thank you very much
Fury
Tone Depth
  • Music Lover
    • SRLPE Wheel Works
Re: Help At Work
« Reply #7 on: 24 Sep 2009, 10:05 pm »
This project may have to do with truth in advertising of rated RMS power to all channels continuously, over a frequency band of 20Hz - 20kHz at 8 ohms specification requirement.
DMurphy
    • SalkSound
Re: Help At Work
« Reply #8 on: 24 Sep 2009, 11:07 pm »
666   Hmmmmmmmmmmm.  Spooooky.    Anyhow, this has to do with truth.  But I can't say what truth.  But thanks for the replies--you saved me a whole lotta work trying to come up with a useable Google key word.  You've told me what I needed to know--it's not very common, but unequal ratings do occur.
doug s.
  • makin' music
Re: Help At Work
« Reply #9 on: 25 Sep 2009, 12:57 am »
maybe not as common in audiophile gear, but i'd wager that w/gear designed for the masses, multi-channel-amped gear, (including receivers), unequal power ratings in the same unit are more common than not...
here's a high-end amp that allows plug-in modules for different power ratings - either a 225w mono amp module, or a stereo 100wpc amp module for each of five module slots:
http://www.ultimateavmag.com/amplifiers/104theta/
doug s.
