NE-7M replacement foam tips
0 Members and 1 Guest are viewing this topic. Read 1353 times.
shadisaleh
« on: 24 Sep 2009, 02:49 pm »
Hi,
I'm wondering what kind of replacement tips are available for the NuForce NE-7M IEM. I've used the Comply T400s, however they don't last very long at all so they make little sense for me to purchase on my student budget.
Are there any other ones you can recommend?
rustydoglim
    • www.nuprimeaudio.com
Re: NE-7M replacement foam tips
« Reply #1 on: 29 Sep 2009, 08:58 am »
Foam material doesn't last very long so your best bet is to go back to silicone tips and find the right fit with the S, M or L size.
minglett
« Reply #2 on: 11 Nov 2009, 03:49 am »
Been using the T400's on my NE-7M's and wear hasn't been a problem, but I haven't subjected them to too much perpiration either. They come in a 3 set pack at Radio Shack. Price isn't bad considering how much better it makes the earphones sound.  I think a company makes a set of silicone ones that have 3 steps of sealing layers. If I find them, I'll post info.
