AUDIOQUEST CV-4 SPEAKER CABLE
0 Members and 1 Guest are viewing this topic. Read 1342 times.
evan1
« on: 23 Sep 2009, 08:11 pm »
Audioquest cv-4 36v dbs speaker cable
12 feet Spade on amp end and banana on speaker side
excellent condition
velour bag , box
CONDUCTORS: All four of CV-4's conductors are solid. Electrical and magnetic interaction between strands in a conventional cable is the single greatest source of distortion, often causing a somewhat harsh, dirty and confused sound. Solid conductors are the most important ingredients enabling CV-4's very clear sound. Whether a conductor is solid or stranded, skin-effect is a prime distortion mechanism in speaker cables. CV-4 very simply keeps this effect out of the audio range by using conductor sizes that are below the threshold for audible distortion.
PERFECT-SURFACE COPPER+: CV-4 uses extremely high purity Perfect-Surface Copper+ (PSC+) conductors. All conductors are solid, which prevents strand interaction, a major source of distortion. Surface quality is critical because a conductor can be considered as a rail-guide for both the electric fields within a conductor, and for the magnetic fields outside the conductor. The astonishingly smooth and pure Perfect-Surface eliminates harshness and greatly increases clarity compared to OFHC, OCC, 8N and other coppers. The superior purity of PSC+ further minimizes distortion caused by grain boundaries, which exist within any metal conductor.
DIELECTRIC-BIAS SYSTEM (patent pending): Unfortunately, because insulation stores and releases energy, it is also a "dielectric." In a cable application, all released energy is distortion. The misnomer "break-in" is often used to describe the pronounced improvement in performance as the dielectric adapts to a charged state as the cable is used. Whenever a cable does not have a charge on it, it is re-adapting to an uncharged state; it is becoming new again.
By maintaining a 36 volt dielectric-bias, far above the voltage of delicate audio signals, the DBS system provides considerably better transparency and dynamics than is possible even from a cable in continuous use. It takes a couple of weeks for the DBS system to reach maximum performance. Since DBS battery packs are attached when CV-4 cables are first terminated, CV-4 will be approaching or at peak performance by the time it is installed in your system. Since there is no "load" on the two standard hardware-store batteries, they will last for years. A test button and LED allow for occasional verification of battery performance.
225.00 SHIPPED AND PP FEES IN THE USA
« Last Edit: 23 Sep 2009, 09:16 pm by evan1 »
