FS: Audio Alchemy DLC Preamp and VAC In The Box Phono
0 Members and 1 Guest are viewing this topic. Read 3476 times.
Alexdad54
FS: Audio Alchemy DLC preamp & VAC In The  Box (VITB) phono  - $425
I have changed to a tube pre so I am selling my AA DLC.
The Audio Alchemy DLC remote controlled preamp is able to control left and right channels independently and the volume control is in precise 0.5 dB steps. This preamp also features an active/passive construction that means that there is no gain added until it is needed. There are 4 RCA inputs and the 2 RCA outputs will allow you to easily bi-amp or add a sub-woofer. A copy of manual is included and it will ship in the original packaging.
The AA DLC handles all functions (volume, balance and input selection) digitally to avoid signal degradation that comes with mechanical switches, switching between the 4 digital inputs by remote control. Each input can be preset to proper volume and balance. LED readouts give you left and right numbers. The all-metal original remote also operates other AA gear, including the DDS Pro Transport System. There is a three-step toggle on the side. The original power cord is included as well as the original Audio Alchemy Power Supply 2 .
An Audio Alchemy Vac In The Box (VITB) phono preamp is also included and comes with its own Power Station One. The VITB uses internal settings to allow you to customize with your favorite cartridge. The manual (such as it is) is also included for the VITB
Both units are in mint condition and are rated a 7 only for age. I am the second owner (AFAIK).
I have feedback on Audiogon under the ID "Daffyd54". All inquiries welcome.
$425+PayPal & shipping from zip 19066 for the two items.
« Last Edit: 24 Sep 2009, 12:09 am by Alexdad54 »
Alexdad54
Re: FS: Audio Alchemy DLC Preamp and VAC In The Box Phono
« Reply #1 on: 10 Oct 2009, 05:16 pm »
Sale pending
