Wonder if the DEQ2496 can output digital signal to another DAC? In any case, based on its rough studio rack design I wouldn't personally consider using it as an EQ in a home stereo.
There is an optical S/PDIF output and an AES/EBU output that could be fed to an external DAC. Of course the jitter added by going in and out of this device is a hot topic in itself! I agree on the studio rack design, and wonder what the Behringer product would be like if offered as a $600 audiophile edition (ESS Sabre 32 DAC, audiophile caps, BNCs, upgraded PSU!), instead of the $300 industrial box it is now.
SRB... so are you really using an HTPC as a music server for digital wav playback? How's that workin for you? I'm a PC too but wouldn't use a computer as a music server, it's just too noisy electrically and mechanically for me to ever consider it audiophile grade.
Yes, I am using an HTPC and iTunes. Currently, I am DAC-less, but I was taking a coaxial S/PDIF out from my motherboard into a Stello DA100 Signature DAC, which to me sounded better than out of my midrange Denon CD player into the same DAC.
The PC sits in my rack in a sexy black brushed aluminum OrigenAE HTPC case, with passive processor and video cooling, Corsair PSU w/ 120mm fan and Noctua low-noise, low-speed 80mm case fans. The OS drive is a quiet single-platter WD, and the data drives are Samsung low-noise F1s. It is not totally silent, but fairly quiet - I can barely discern its running from my seating position if no sound is output through the speakers and everything else in the room is off.
I also use the PC with Vista Media Center and am able to record 4 shows at once (2 - SD and 2 HD) and can simultaneously play music from iTunes without skipping a beat!
I'm sure I could improve on the sound, and like most audio nutcases am thinking and plotting a better sounding setup, but for now, it actually sounds pretty good, even in the face of the all the theoretical PC interference.
