Sketchup model of M-130 by Carlos
0 Members and 1 Guest are viewing this topic. Read 2158 times.
Voncarlos
  • OB5s in Stripes
« on: 22 Sep 2009, 11:09 pm »
I've just recently taken the time to investigate Google's "Sketchup", the 3D modeling program that many folks seam to be using for drawing up there speakers. I've started a model of the OB5 I'm working on and have created separate models of the M-130 and Neo3 PDR drivers. If anyone would like a copy of them please send me a private message with your email address and I will send them to you.
The M-130 is 1.44 Mb uncompressed or 512kb zipped.
The Neo3 PDR is 407kb in size.
They are in .skp file format, which is the file format for "Sketchup.
Sketchup is a great little program for 3D modeling and the best thing is, you can download it for free from Google. It's not the best, and there are other free 3D modelers out there but it's just fine for what it does. And it's FREE.
I've lightened up the black color used so the models will be visible on a wide variety of monitors.
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
Re: Sketchup model of M-130 by Carlos
« Reply #1 on: 25 Sep 2009, 03:00 pm »
Very cool of you to do this and share it...  :thumb:
I played around with sketchup last night... but I need to go through the tutorial. It's not super intuitive.  :?
tmoney1876
« Reply #2 on: 28 Sep 2009, 04:01 am »
This could be useful if anyone wanted to make alternate box shapes for the n3s...
Very cool.
srb
« Reply #3 on: 28 Sep 2009, 04:16 am »
No, it's not.  I had enough trouble building rectangular kitchen cabinet objects.  Building these driver objects is on a whole other level without having the sophisitication of AutoCAD tools.  Nice work.
Danny Richie
« Reply #4 on: 28 Sep 2009, 12:31 pm »
I am amazed at how accurate this look. Definitely some skill involved.
Voncarlos
  • OB5s in Stripes
« Reply #5 on: 28 Sep 2009, 05:19 pm »
Yes, I agree, it's not super intuitive. And that's coming from someone who has had years of experience with most graphics design software and quite a bit of 2D Autocad. It takes a lot of forethought and planning to create compound curves that intersect with other compound curves.
Instead of creating something in the order of, step A, step B, step C, you have to make a rough "step C" and then cut away "step B" and "step A" to end up with the finished part. Still, once you get the hang of the great tools like "extrude" and "scale", it's a lot of fun.
For me the Google tutorials are painful to go through, and don't really show you all the creative ways of using the various tools in unison, so I bought a book to help me get running quickly with this. I'm not a big fan of the "Dummies" books, but the "Sketchup 7 for Dummies" is done nicely and I'm still working my way through it.
There is a balance to keep in mind, keeping the model detailed and small in file size.
The M-130 driver is made up of groups within groups. So, if one were to only see the face of the driver you could completely delete the whole backside of it, thus having a smaller file. You can also scale it to match whatever size driver you needed.
Zero the Hero
« Reply #6 on: 28 Sep 2009, 06:06 pm »
that is impressive! Thanks for sharing! I've tried probably 3-4 times to use that program, and never really got anywhere with it.
