Mods to 4NRB still available?
0 Members and 1 Guest are viewing this topic. Read 2146 times.
Jonathan
« on: 22 Sep 2009, 09:49 pm »
I have a line on a used 4NRB. Although the 4BSTs used show up fairly often in my (ballpark) price range, I wondered if I can still get the 4NRB modded/updated by Bryston for a reasonable amount of money.  If so, what kind of $$ are we looking at? Thanks much!
  • The Demo is Everything!
    • http://www.bryston.com
Re: Mods to 4NRB still available?
« Reply #1 on: 22 Sep 2009, 10:25 pm »
Hi Jonathan,
There is no upgrade path from and NRB to and ST.
james
Jonathan
« Reply #2 on: 23 Sep 2009, 12:55 pm »
Okay, thanks. Anywhere to go with the ST series? Again, I appreciate your help.
Jon
« Reply #3 on: 23 Sep 2009, 02:47 pm »
Jon
Hi Jon,
No I am sorry there are no upgrade paths from series to series.
james
Hififreak
  • www.brystonheritage.com
    • www.hififreaks.nl
« Reply #4 on: 23 Sep 2009, 08:37 pm »
Jon
Hi Jon,
james
Deutsch: Is there an update program to convert an earlier version of an amplifier into an ST Series?
Chris Russell: We can do it on most of the NRB series. It's not inexpensive?about $500?but it can be done. Also, the 7B, for reasons of physical construction, is almost impossible to upgrade from the NRB series. The 3B and the 4B can be done.
Klik.
« Reply #5 on: 23 Sep 2009, 11:35 pm »
Jon
Hi Jon,
james
Klik.
Hi
That was a question and answer about 15 plus years ago and we did try for a while but it soon became obvious that it was not cost effective.
james
