need help finding parts for my chime
0 Members and 1 Guest are viewing this topic. Read 1250 times.
harryf
« on: 22 Sep 2009, 06:37 pm »
I'm amassing the parts for my chime.I need some help.
I need equavalent parts for lm7808/njm78m08fa.I bought a part to replace this but i see it's only a 1 a part.It's 512 lm7808ct. I need the right part and am a bit confused.
sip-20/ a26428.I need the equivalent part as it's out of stock.
harryf
Re: need help finding parts for my chime
« Reply #1 on: 24 Sep 2009, 02:28 pm »
I won't be able to build this without these part's?Any idea's these parts are out of stock now?
orpheus
search Digikey, they have them in stock right now.
« Reply #2 on: 28 Sep 2009, 09:38 pm »
Search for LM7808 in Digikey, they have them in stock.  It has been a while since I built my Chime, so check to make sure that the specs are the same for that part as the one that is specified in the instructions.
Good luck with your build, it is a great sounding DAC.
Best,
Aaron.
hagtech
    • http://www.hagtech.com
« Reply #3 on: 30 Sep 2009, 11:23 pm »
I have a hard time keeping the printed parts lists up to date.  You can search on "78M08" at digikey and come up with alternatives.  The package does not need to be isolated (as in the originally specified part).
jh
