choice of CDPlayers and speakers?
0 Members and 1 Guest are viewing this topic. Read 2074 times.
guest1632
  • Guest
« on: 3 Jan 2004, 10:30 pm »
Hi, am considering one of three cdP's don't have a ton of money to work with, so: Cec from audio Advisor, Music Hall cd25 and the new NAD 542I.
Also, has any one listened to the EFE speakers? Thanks.
Pin
« Reply #1 on: 4 Jan 2004, 04:46 am »
Did you mean NAD C541i or C542? NAD has just got the C542 out and I don't think they would replace the model with an improved version any time soon.
Zero
« Reply #2 on: 4 Jan 2004, 05:01 am »
You can find an NEC 601 ROM drive for roughly $20 bucks on Ebay.  I seriously doubt the above names listed could remotely keep pace with it. ;)
Pin
« Reply #3 on: 4 Jan 2004, 06:01 am »
A NEC Rom drive?? I do not think so.......
Tonto Yoder
« Reply #4 on: 4 Jan 2004, 06:16 am »
Quote from: Pin
I've thought about getting one of the NEC drives based on previous threads here. This review was included in one of those threads--
http://positive-feedback.com/Issue3/cdrom.htm
guest1632
  • Guest
« Reply #5 on: 4 Jan 2004, 08:07 am »
Quote from: Pin
RooX
« Reply #6 on: 4 Jan 2004, 04:25 pm »
perhaps you should try it before you knock it pin.  The nec drive has quite a following as one of the best transports at any price.  Buy it for 20 bucks, a decent digital and something like an dAck! and there is little doubt that it would destroy the NAD.  Hell i had it and a melior dac up against my $6000.00 player and in a lot of ways l liked the NEC more!.
cheers
guest1632
  • Guest
« Reply #7 on: 4 Jan 2004, 11:25 pm »
Quote from: RooX
cheers
Rob Babcock
« Reply #8 on: 4 Jan 2004, 11:39 pm »
Is there any way to do the normal CDP things w/a CD ROM drive, (eg. FF, REW, PAUSE, Prog, etc)?  Seems like you'd lose some of those funcions.
guest1632
  • Guest
« Reply #9 on: 5 Jan 2004, 04:02 am »
Quote from: Rob Babcock
Well Rob, don't know, I was originally asking about choices of three cdplayers, which to get. I also asked if anyone has heard any of the EFE speakers from Ed Frias?
Pin
« Reply #10 on: 5 Jan 2004, 07:31 am »
Ray,
I have not heard the 3 CDPs listed but am getting the C542 (which is not even out yet) myself. Right now I am using a NAD 541 - which my dealer has lent to me til he gets the C542 in - with a NAD C372 and pair of Monitor Audio Bronze B2s. As you can see, I am no where near the audiopile level. However, I do think my humble kit does pretty well in music play-back and I am very satisfied with its performance. Anyway, you can find a review on the C542 at www.audioenz.co.nz. Hope this helps.  :)
guest1632
  • Guest
« Reply #11 on: 5 Jan 2004, 03:19 pm »
Quote from: Pin
Ray,
JoshK
« Reply #12 on: 5 Jan 2004, 03:31 pm »
I just won an ebay auction for one of the NEC drives ($10.50!).  I will let you know my thoughts when I get it.
Josh
Pin
« Reply #13 on: 5 Jan 2004, 03:37 pm »
Sure thing Ray!  :D
I should be getting the C542 within this week. By the way, where did you hear about the C542i? There is no info about the CDP on the NAD website.
guest1632
  • Guest
« Reply #14 on: 6 Jan 2004, 01:45 am »
Quote from: Pin
Sure thing Ray!  :D
I thought I read it on the site, maybe transposed the 542. I'm told it's about $500.
Pin
« Reply #15 on: 6 Jan 2004, 02:34 am »
Thanks for the info. :)
