14B tick/pop
0 Members and 1 Guest are viewing this topic. Read 5965 times.
KeithA
14B tick/pop
« on: 20 Sep 2009, 03:50 pm »
I've noticed lately that there's a tick or pop when I power down the 14BSST. I gues it's some sort of charge from the caps, etc.
Anyone else get any of these when powering down?
Keith
b5pt9
Re: 14B tick/pop
« Reply #1 on: 20 Sep 2009, 04:29 pm »
The powerdown circuit can malfunction so you may want to watch this.  I had to send in my 4BST because it started squealing pretty good on powerdown and I was worried any DC component might cook my drivers.  Warranty or course.
« Last Edit: 20 Sep 2009, 05:42 pm by b5pt9 »
KeithA
Re: 14B tick/pop
« Reply #2 on: 20 Sep 2009, 05:29 pm »
James
Does this sound normal for the 14B or should I contact Mike Pickett about maybe sending it in. If it goes in, I may as well get the Swedish upgrade as well  :lol:
I guess she needs to be in top shape before I trade her in on a set of monoblocks :oops: Just kidding....maybe  :wink:
Keith
  • The Demo is Everything!
    • http://www.bryston.com
Re: 14B tick/pop
« Reply #3 on: 20 Sep 2009, 06:10 pm »
James
Keith
Hi Keith,
It just sounds like the turn-off relay so I do not think it is much of an issue but its worth checking with Mike.
james
danman
Re: 14B tick/pop
« Reply #4 on: 20 Sep 2009, 07:38 pm »
My 4BSST2 always lets out a little pop when shutting off so I guess this is normal!!?
It is not loud at all so it can't hurt anything.
95Dyna
Re: 14B tick/pop
« Reply #5 on: 21 Sep 2009, 01:28 pm »
James
Keith
Keith,
If you trade it in for a pair of 7's you'll have 2 ticks when you shut them down.  I've heard other amps make worse sounds when shutting down.
KeithA
Re: 14B tick/pop
« Reply #6 on: 21 Sep 2009, 02:07 pm »
James
Keith
Keith,
If I'm going to go monoblocks from the 14B...it won't be the 7's  :wink:
Keith
KeithA
Re: 14B tick/pop
« Reply #7 on: 21 Sep 2009, 02:08 pm »
95Dyna
Re: 14B tick/pop
« Reply #8 on: 21 Sep 2009, 03:36 pm »
James
Keith
Keith,
Keith
My point was that the tick/pop you're hearing is normal.  I wasn't speculating on what mono's you might acquire.  I assume the wink means 28's.   :thumb:
KeithA
Re: 14B tick/pop
« Reply #9 on: 21 Sep 2009, 03:48 pm »
James
Keith
Keith,
Keith
Yeah, just having a little fun :)
The 28s would be it and I'm toying with trying to get a listen to a pair.....but it would be hard to do living on the far east coast of Canada. So, an upgrade is not a sure thing....I'd never do it woithout getting to try them.
Keith
danman
Re: 14B tick/pop
« Reply #10 on: 21 Sep 2009, 04:47 pm »
Believe me...................you don't have to listen to them................BUY THEM!
drummermitchell
Re: 14B tick/pop
« Reply #11 on: 21 Sep 2009, 04:56 pm »
 :o :D.
95Dyna
Re: 14B tick/pop
« Reply #12 on: 21 Sep 2009, 06:37 pm »
James
Keith
Keith,
Keith
Keith
You don't have to live in Newfoundland to have that problem.  The day my 7B's arrived was the first time I had ever seen a 7B let alone heard one and I live within a short distance of Philadelphia, Baltimore and Washington D. C.  I couldn't find a dealer within 4 hours of my home that had anything bigger than the 4B available for demo.  Just for kicks I bought a BP26 sight unseen/heard as well.
KeithA
Re: 14B tick/pop
« Reply #13 on: 21 Sep 2009, 06:38 pm »
Not a chance  :wink: If I can't get them in my room for at least a couple days to try....it's a 'no go' :D
Getting them in there to try will take some creativity....and likely can't be done.
Keith
Laundrew
Re: 14B tick/pop
« Reply #14 on: 21 Sep 2009, 07:26 pm »
James
Keith
Keith,
Keith
Hello
The only noise that my 28Bs make on power-up is a slight click and "buzz." Most likely the soft start circuit? On power off - nothing but the normal click.
Be well...
KeithA
Re: 14B tick/pop
« Reply #15 on: 21 Sep 2009, 07:38 pm »
James
Keith
Keith,
Keith
Hello
Be well...
Exactly...I'm pretty sure that's the way mine was as well. Lately, Im getting a pop (electrical discharge) in the speakers.
I'll run it by Mike @ Bryston
Keith
Laundrew
Re: 14B tick/pop
« Reply #16 on: 21 Sep 2009, 07:42 pm »
James
Keith
Keith,
Keith
Keith
Keith...Get in the car and start driving :wave: :icon_arrow: :rock: :icon_arrow: :thumb:
KeithA
Re: 14B tick/pop
« Reply #17 on: 25 Sep 2009, 06:13 pm »
To update....
I've been talking to Mike Pickett via email & phone (as well as doing a little research myself on the net) and the popping may be caused by a small amount of DC voltage on the outputs.
There is a DC Offset adjustment that can be done on the amps, if required. I tested all three (3) outputs on my 6B and they tested +/- 0.000 volts...perfect.
The 14B SST tested +0.005 & 0.011 volts on outputs. So, we'll do a little adjustment to bring them down to zero (which is where they are targeted to be) and hopefully that takes care of the popping  8)
Keith
KeithA
Re: 14B tick/pop
« Reply #18 on: 26 Sep 2009, 11:12 am »
To update....
Keith
Quick adjustment to DC Offset (+/- 0.000s across the board) but the amp is still popping like a banshee. Funny, even my wife noticed yesterday that the speakers were popping when the stereo was being turned off.
So, I'll send it off to Bryston next week for a look-see.
Keith
vegasdave
Re: 14B tick/pop
« Reply #19 on: 26 Sep 2009, 06:23 pm »
James
Keith
Keith,
Keith
Hello
Be well...
That's exactly what my 4B does. I take this to be normal operation?
