0 Members and 1 Guest are viewing this topic. Read 12402 times.
Never heard of the Super Track! Anyone else know it?
I replaced the cartridge and it came with a new stylus. It sounds much better now. The needle itself looks smaller and I am not getting as much sound emanating from the needle as before (what you hear w/ record playing & amp volume off). The new cartridge is angled differently and the tone arm is straighter (not as much dip towards the record). I set the weight properly too. Some LP's still don't sound too good- but maybe that's the LP. Highs on some LP's can get raspy if their at high volumes. I aligned the cartridge in the headshell with a micrometer and got it within .01mm. Note: My cartridge isn't expensive. It's a Shure M92E. The spec's seemed good and it's an old turntable. I didn't want to spend too much.
I hear no sound coming off the vinyl until I get my ear within about 6" from the LP.
A digital micrometer helped me out, not so much my eyes. The micrometer was placed from the cartridge screw head to the back of the headshell mounting track. I did this for both screws and made sure it was held in exactly the same place.
I think you hit on something: A tracking error. I don't know if much can be done about it with such an old turntable. I can't feel any resistance form the tone arm, but it's possible. Inner tracks seem to have more issues than outer tracks. The anti-skating control is in the center detente.
