0 Members and 1 Guest are viewing this topic. Read 3879 times.
It sounds like I'm "good to go" with the dbpoweramp and FLAC setup.
Quote from: TomW16 on 17 Sep 2009, 09:59 pm It sounds like I'm "good to go" with the dbpoweramp and FLAC setup. When you're ripping the disc through EAC, you are clicking [copy selected tracks] then [compressed], correct?You're not using true RAID, but from my experience, I (now have) reservations about using RAID in some forms. I'd rather have what you've got .Bob
Hi Bob,I haven't done any ripping yet. My main computer went down so I've got some time to figure this stuff out. I was surfing the dbpoweramp site and noticed that they have a bundle with a Teac drive that is litteraly plug and play in that you put in a disc and it rips, tags and stores it for you automatically and then spits it out when it's done. It's a bit pricey at $184 but the Teac drive they use is relatively expensive. My original plan was to simply use my computer to rip and then transfer the files to the server rather than direct to server. Any comments on either approach?Thanks.Tom
The automatic ripping with the TEAC drive is enticing but I wonder if simply using any CD burner would work with the Reference software? I did read the TEAC advantages (less errors) but with the auto correction (or re-read) feature of dbpoweramp, I am unclear on why the TEAC drive is necessary if I simply went with the Reference software?Tom
3: don't sell all your cd's unless you are confident you have bit perfect, uncompressed backups!
