Right channel AWOL on Piccolo
0 Members and 1 Guest are viewing this topic. Read 1349 times.
Swarkybubble
« on: 17 Sep 2009, 10:56 am »
Any suggestions on where or the best way to proceed to start searching for the culprit ?
No, it?s not for me, mine?s still being built "a la tubesforever", it?s for a mate in the UK who knows even less than me about these things.
Thanks for any suggestions.
P.S. - It?s a basic, battery-powered kit version, by the way.
hagtech
Re: Right channel AWOL on Piccolo
« Reply #1 on: 18 Sep 2009, 01:17 am »
Did the channel work ok and then go bad?  Or always bad?  Start with power supply rails, make sure they match left/right.  Then check resistor values.  Often it is just the wrong value in wrong spot.
jh
Swarkybubble
« Reply #2 on: 18 Sep 2009, 04:01 pm »
Hi Jim,
No it was fine and my mate left it on overnight, inadvertently. When he came to try and use it again, the right channel had gone AWOL.
Swarkybubble
« Reply #3 on: 22 Sep 2009, 07:58 pm »
Hi Jim,
After fitting new batteries and taking out his multitester my techie says he gets  a voltage difference of something like 1.13v at the first gain stage and 1.24v at the second in favour of the left hand channel. After checking the resistors are Ok, the conclusion my techie has reached is that the jfets must be faulty on the right hand channel. Apparently they are going to be a real pain to try and change so would you recommend a new board in such a case or can they be repaired ?
hagtech
« Reply #4 on: 23 Sep 2009, 07:25 am »
Hmmm, I doubt it is the JFETS, unless the input tooka big ESD (lightning type) strike, which is possible.  That could do it.  Winter down under?
If you're really good at soldering, the parts are not that hard to replace.  Let me know offline.
jh
Swarkybubble
« Reply #5 on: 23 Sep 2009, 10:04 am »
Thanks Jim,
I?ll get my technical mate and solderer to contact you direct and explain exactly what he has found.
Chris
