SW-12B in SW-12-04 enclosure?
0 Members and 1 Guest are viewing this topic. Read 1966 times.
yoder
« on: 17 Sep 2009, 02:23 am »
I was having a basic 1.25 cu ft box built by Elemental Designs with one brace for an SW-12B, but a 1.5 cu ft SW-12-04 design was built instead.  I already had a spare 150W amp and bought the SW-12B, so even thought I have upgradeitis, I don't want to buy an SW-12-04 and a servo amp right now.  However that could be a future upgrade though and this is a better enclosure than the one I ordered.  I have one sheet of no rez to use.  Can I just put something in the enclosure to take up the extra .25 cu ft?  How will the sound be effected if I use the larger enclosure?  I don't want mount the driver and test it just yet as I can still send it back and get the smaller cabinet built.  Thanks!
stevenkelby
  • Adelaide, South Australia
Re: SW-12B in SW-12-04 enclosure?
« Reply #1 on: 17 Sep 2009, 02:25 am »
I would keep it for sure and put a brick or something in to take up the extra 0.25 cu ft. till you upgrade.
Danny Richie
« Reply #2 on: 17 Sep 2009, 01:47 pm »
If all that you are driving it with is a 150 watt amp then you are fine. Leave the enclosure as is, put it all together and enjoy.
yoder
« Reply #3 on: 18 Sep 2009, 03:20 am »
Thanks!  I'll start putting it together tonight.
corndog71
  • Some people call me Rob.
« Reply #4 on: 18 Sep 2009, 04:10 am »
save your money for that servo amp.
It makes beautiful music. aa
