0 Members and 1 Guest are viewing this topic. Read 9117 times.
Welcome to the world of vinyl. I don't agree that you have to start from bottom up. I understand Wayner's point but why toil with limited sound when you know there is glory to be had. If you do your research and due diligence, there is no reason why you couldn't plunge directly into vinyl esoterica. It would be helpful to get someone experienced to help with the initial set up. I find the better stuff to be easier to set up. For example, Teres TT and Graham Phantom II arm combo was a breeze to set up. Having a detachable arm wand with fool-proof cartridge mounting tool (no need for a protractor), on the fly VTA and azimuth control, and movable arm-mount all makes the job very easy. Origin and Rega arms are much more PITA in comparison especially with fixed arm mounts. So do your research and get the best analog you can afford. Spare some of your money for a phonostage and pickups. A couple of different flavors will do you good. Ask a friend or "hire" an expert/dealer for the inititial set up. Watch and learn. Then plunge in and enjoy!P.S. You have to learn how to clean your records too. RCM is very helpful but not necessary.
Hard to go wrong with anything in that price range
BTW: Take a real close look at the less expensive 'Table, it's very special.
Quote from: JimJ on 13 Sep 2009, 05:39 amHard to go wrong with anything in that price range Funny, but we only can hope that holds true. What I was missing for many years in my experience with records was a properly set up and aligned cartridge. No bass, no highs and a muddy middle are all you can expect without a proper set up using a protractor. Most people who like CD's better have never heard an aligned needle. The others just like the convenience of CD's too much to be open minded.Cartridge Alignment ProtractorsCartridge Alignment Protractors | Free Turntable, Tonearm & Cartridge Tools | Vinyl EngineCartridge Alignment productsCartridge AlignmentAlignment ProctratorsTurntable Accessories-Audio AdvisorI have the DB Systems protractor, difficult (but not impossible) to use with non-rectangular bodies.Use one of these too..........I know..sooooo much work.Cardas Frequency Sweep and Burn-in Record ? Good also to set anti-skatingCardas Audio
