NRB acronym
0 Members and 1 Guest are viewing this topic. Read 5742 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: NRB acronym
« Reply #20 on: 16 Sep 2009, 11:20 am »
James,
Are the NRB/NPB and ST the same?
Hi  Stu,
NO -- big changes with the ST.
james
Levi
Re: NRB acronym
« Reply #21 on: 16 Sep 2009, 01:33 pm »
James,
Hi  Stu,
james
Hi James,
Just like going from NRB to SST.  Do you consider going from SST to SST-SQ version big changes?
--Levi
1ZIP
Re: NRB acronym
« Reply #22 on: 16 Sep 2009, 03:46 pm »
 The 'NRB' stood for 'NEW REGULAR BALANCED' and the NPB stood for 'NEW PRO BALANCED'.
james
....Regular Balanced....Pro Balanced.???
Re: NRB acronym
« Reply #23 on: 16 Sep 2009, 03:54 pm »
james
It was when we started offering Balanced inputs on Consumer amps.
james
1ZIP
Re: NRB acronym
« Reply #24 on: 16 Sep 2009, 04:24 pm »
It's early and I probably haven't had enough coffee so maybe I'm missing something...but what is the difference between REGULAR and PRO?
b5pt9
Re: NRB acronym
« Reply #25 on: 16 Sep 2009, 06:49 pm »
Typically the Bryston Pro version amps have trim pots so you can adjust each channel gain.
vegasdave
Re: NRB acronym
« Reply #26 on: 16 Sep 2009, 11:35 pm »
Yep. Plus, you can get the pro amps at less cost.
