HT3s and cutover for sub
0 Members and 1 Guest are viewing this topic. Read 1611 times.
texas steve
« on: 10 Sep 2009, 10:00 pm »
Ive had some of Jims HT3s for 2+ years - great speakers.  I just added a Anthem D2v processor and for LFE movies I need to know what crossover freq I should use for My sub in relation to the HT3s.   Any advice greatly appreciated.
jermmd
Re: HT3s and cutover for sub
« Reply #1 on: 10 Sep 2009, 10:24 pm »
Are you using the sub only for movies or for music too?
I think I have my HT3's crossed at 60hz. What subwoofer are you using?
Play with different settings and see what you like. For music I might set the HT3's to large or set the crossover even lower-maybe 40 or 50hz.
texas steve
« Reply #2 on: 10 Sep 2009, 10:42 pm »
I have a old Muse 18 sub.   I only use the sub for movies and yes I too set them for large with music and small for movies.
Nuance
« Reply #3 on: 10 Sep 2009, 11:32 pm »
Can you take any in-room response measurements?  If so, you can experiment with different crossovers/phase and see which achieves the smoothest response.
texas steve
« Reply #4 on: 11 Sep 2009, 12:49 pm »
Yes I can thanks.  Jim said the HT3 go to 29hZ so he suggested setting by sub to 35hz
