47K vs 100K loading
0 Members and 1 Guest are viewing this topic. Read 1692 times.
BobM
47K vs 100K loading
« on: 8 Sep 2009, 04:34 pm »
Jim,
Don't know if you've seen it but there's a hugh thread over at Audiogon about old MM cartridges. One of the things these people seemed to uncover is that the traditional 47K loading seems to be inferior to a 100K loading. here's the thread:
http://forum.audiogon.com/cgi-bin/fr.pl?eanlg&1200430667&openfrom&660&4#660
Just wondering of you ever experimented with this or if you have any insights or comments?
I have a Trumpet and love it. I'm using a Dynavector HOMC (XX-1) with it and am wondering if this 100K loading might be appropriate. Just wondering which resistor I need to change out if I were to experiment a bit to see if I can hear a difference?
Bob
hagtech
Re: 47K vs 100K loading
« Reply #1 on: 11 Sep 2009, 12:48 am »
I doubt the higher loading is going to help a modern Dynavector.  The 100k+ is good for old Shure carts, mainly.  It also really helps to remove all capacitive loading.
jh
nimrod
« Reply #2 on: 12 Sep 2009, 05:20 am »
I can attest to using 100K for Shures. I just installed the resistors into my Bugle, which uses Holco/PRP
resistors, Orange drop cap's, OPA627's in U3, and is battery powered. I'm using a Shure V15 VxMR, and am
very impressed by the difference; greater dynamics with a fuller midrange.
