software to test speakers?
0 Members and 1 Guest are viewing this topic. Read 1605 times.
acwd1950
« on: 8 Sep 2009, 12:51 am »
I am getting ready to build some BIB speakers using a couple of Tang Band w4-1052sd speakers. I downloaded a calculator/sheet from another site and using that to build the boxes. I need a program that I can test the frequency response after I get them built to see if there are any peaks and such? I have a microphone but need some software. Prefer some thing free or cheap? Thanks
Sarmck
Re: software to test speakers?
« Reply #1 on: 8 Sep 2009, 02:59 am »
This may give you something to work with.  http://www.marchandelec.com/programs.html
From the Marchand Electronics site:  "Windows program implements a very simple function generator using the pc sound system.  Generates sine wave signals from 20 Hz to 20 kHz. Also has white noise and pink noise."
Ron
jk@home
« Reply #2 on: 8 Sep 2009, 11:24 am »
JimJ
  • Ut Prosim
« Reply #3 on: 8 Sep 2009, 06:10 pm »
TrueRTA (the paid version with 1/6-octave response) gets my vote :)
hobbyhands
« Reply #4 on: 9 Sep 2009, 02:58 am »
Hello. I think the best free and easy to use software is arta
http://www.fesb.hr/~mateljan/arta/
Thats is what I use.
My setup
Arta demo (Fully functional, but can't save freq responses. I just copy the screen using windows print screen function an save my files as jpegs.)
ECM800 Mic
M-Audio Firewire sound card(works as a pre amp and has phantom mode)
Using my denon receiver
