I only need a pre-preamp
0 Members and 1 Guest are viewing this topic. Read 1603 times.
hifitommy
« on: 1 Jan 2004, 05:10 pm »
that is, about 30db of gain to overcome the tube rush in my arc sp3c.  when using a mc and a transformer of about 20db of gain (ortofon T20), the gain just isnt quite enough.
is ther or could there be a hagtech product with this capability (30db of gain) and say some adjustable impedance?
this is hopefully going to be in the BUDGET category.  i dont need another preamp, i need a gain stage.
hagtech
« Reply #1 on: 2 Jan 2004, 08:10 am »
They are traditionally called "head amps".  Usually solid-state gain stages built for small signal and super-low noise.  You need to be careful not to overdrive the inputs of your phono stage.  I would think a head amp plus stepup into a tube phono stage would be too much.
So far I have no plans for such a device.  Too busy designing my new Constructor series of half-kits: Cornet phono, Clarinet linestage, Chime DAC, and Cymbal monoblock.
jh :)
