stepping speaker down to line output?
0 Members and 1 Guest are viewing this topic. Read 1725 times.
dayneger
« on: 1 Jan 2004, 10:18 am »
I'm laying out my future budget HT system, which will need to integrate with my 2-channel system.  Basically I have a problem that the cheap HT receiver doesn't have preouts for LR.   :scratch:
Are there standard cable/converter thingies that would allow me to take the LR speaker outputs of the HT receiver and run the signal as a line input into my 2-channel amp?  And where could I get my hands on one?
Thanks in advance for any info!
Dayne
Rob Babcock
« Reply #1 on: 1 Jan 2004, 01:34 pm »
Yes.  Parts Express sells one, and so does Rat Shack.  I don't have the parts number handy but this topic was discussed here about 6 months back, so I'm sure a search would dig it up.
BTW, Carver used to make a product they called a "Z coupler" (Z for impedance)  to hook up their amps to a reciever.  You can sometimes still find them on Ebay.
Your best bet though is going to http://PartsExpress.com and looking there.
-R-
dayneger
« Reply #2 on: 3 Jan 2004, 08:49 am »
Thanks, Rob, I'll hunt them down.
That is, if I can ever get into the PE site!   :evil:  For some reason it never loads on my computer at home.  Just sits there hanging!  PITA.  Maybe it'll work at my office.
Dayne
