Peachtree Nova - Rosewood - SOLD
0 Members and 1 Guest are viewing this topic. Read 975 times.
johsti
« on: 31 Aug 2009, 06:10 pm »
I have a Peachtree Nova in Rosewood for sale.  Asking SOLD shipped to the lower 48.  Please add 3% for paypal.    Includes original double box, remote and manual.  I will post pics soon.  Very conservatively rated at a 8/10 on the audiogon scale due to a very minor nick in the rosewood finish on the bottom.  Other than that, it sounds great and works perfectly.  Check my feedback on audiogon under the same username.
Here are the specs
    * 80 watts x 2 channels into 8 ohms
    * hybrid vacuum tube/solid-state design
    * vacuum tube preamp stage (uses a single dual-triode input tube)
    * high-current class A/B solid state power amp
    * built-in ESS 9006 Sabre 24-bit/192kHz upsampling digital-to-analog converter (DAC)
    * decodes MP3, AAC, WMA, FLAC, AIFF, WAV, PCM, and Apple lossless
    * high-capacity toroidal power transformer
    * digital audio inputs: 1 USB (Type B), 2 optical (Toslink), and 2 coaxial (S/PDIF)
    * 3 pair RCA analog audio inputs (3rd analog input doubles as a "Home Theater Bypass" to insert Nova into a multichannel system)
    * 2 pair RCA audio preamp outputs (for connecting a powered subwoofer, outboard power amplifier, or using the Nova as a stand-alone DAC)
    * headphone output (full-size 1/4" jack)
    * bass EQ switch with +6dB boost at 50Hz
    * heavy-duty binding-post speaker connectors
    * detachable AC power cord
    * remote control
    * 14-13/16"W x 4-13/16"H x 14-1/4"D
    * warranty: 1 year on amp, 6 months on tube
« Last Edit: 11 Sep 2009, 07:22 pm by johsti »
