FS:Penderaudio dipole speakers, hawthorne drivers
0 Members and 1 Guest are viewing this topic. Read 13698 times.
penderaudio
« on: 30 Aug 2009, 04:48 pm »
For sale pair of: Pender Audio 310 prototypes
These will be the foundation for my new line of speakers.
-1 10" Hawthorne Audio PSI "per side"
-2 10" Hawthorne Audio Augies "per side"
-Solid Bamboo construction (horizontal carbonized grain)
-Semi-gloss Polyurethane finish
-Flush mount grills
-About 50hours play time
-ASKING $1800 O.B.O
For Sale One Pair: Pender Audio "House Wreckers"
A five month project over 200 hours spend on the build!
1- 10" Hawthorne PSI "per side", "screen has been removed from compression drivers
2 15" Exodus XJ-15's "per side" Drivers from Kevin at DIYcable.com
(Paper cone, XBL^2 motor design, 27mm X-max one way, Dual 8ohm coils, 220oz. magnets, Qts-.67Fs-24hz,
2.5"Voice coil's, 750 watts RMS power handling. Nice big subs.
-Maple and African Mahogany real wood veneer
-Gloss Polyurethane finish
-About 160lbs. each
-Hand delivery and setup avaliable within 500miles of Rhinelander,WI 54501
-Freight delivery estimated cost of $500-$600
-About 150 hours play time
Asking $3000 O.B.O.
High Res photos available upon request
Post or e-mail me with ???
[email protected]
-Jamie-
« Last Edit: 22 Oct 2009, 02:56 pm by penderaudio »
Angaria
Re: FS:Penderaudio dipole speakers, hawthorne drivers
« Reply #1 on: 5 Sep 2009, 04:00 am »
Nice looking cabs with the XJ15's.  Are those veneered sonotubes?
penderaudio
« Reply #2 on: 8 Sep 2009, 01:09 pm »
The XJ sub tubes are 15" PVC. They are heavy and very strong, about 1/2 inch thick material.
The cabinets are just baffles for the XJ's, there is no back so they run open baffle.
-Jamie-
penderaudio
« Reply #3 on: 19 Sep 2009, 02:14 pm »
Price Reduction  :D
$2000 OBO for the 310 bamboo speakers
$3200 OBO for the "House Wreckers"
I would like to move one of the pairs.
-Jamie-
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #4 on: 20 Sep 2009, 01:13 pm »
Nice looking cabinets is an understatement! Those are gorgeous dude! Okay, are the XJ-15's in a U-frame? Almost seems like it given the driver is stuck inside a tube with an open back. Is there an active crossover as such between the Hawthorne Coaxial driver and XJ-15's as such?
Again, beautiful work.
Anand.
penderaudio
« Reply #5 on: 20 Sep 2009, 04:15 pm »
Correct the XJ's are in a U-frame they work well up to about 80hz. Yes there is an active crossover between the XJ's and the 10" silver iris's. It is a DBX-223 fixed slope at 24db set around 75hz.
I use two B&K amps one for the woofers and one for the Silver Iris's.
The key word I would use to describe the "Housewreckers" is OUTPUT :green: they play well at any sane level and beyond.
-Jamie-
poseidonsvoice
« Reply #6 on: 20 Sep 2009, 05:35 pm »
-Jamie-
Indeed. A single driver in a U-frame is equivalent of two in an H-frame, i.e. there is 6dB more output in a U-frame. Now you have (2) U-frames per side with a woofer that nobody would call a slouch!
I'm sure for the truly psychotic you could seal the U-frame easily and get a touch more output in the lowest octave. But when you already have (2) U-frames, what's the need?  :rock:
Anand.
penderaudio
« Reply #7 on: 21 Sep 2009, 09:09 pm »
Ya they work well in larger rooms where extra low end output is needed.
-Jamie-
penderaudio
« Reply #8 on: 22 Oct 2009, 02:56 pm »
Have not had much action on either so I'm doing another price drop
$1800 for the 310 Bamboo speakers
$3000 for the House wreckers.
-Jamie-
