Escalante Design Pinyon monitors, Hoodoo stands and a single Uinta subwoofer
0 Members and 1 Guest are viewing this topic. Read 4895 times.
mikeg1
Editor's Choice for Stereotimes Most Wanted Components (Pinyons & Uinta)
Escalante Design Pinyon monitors, Hoodoo stands and a single Uinta subwoofer. Original owner and excellent condition. Both monitors and subwoofer have the matching upgraded high gloss black finish ($1000 for each speaker type). Includes six Audiopoint cones for Pinyons. Original pricing for Pinyons and Hoodoo stands was $10,995 and single Uinta subwoofer was $7990.  I have the all boxes and crates for the Pinyons and Uinta subwoofer.
$5,995 for Pinyons, Hoodooh stands and Uinta sub plus shipping (will sell Pinyons and stands for $3,995 and Uinta sub for $1995 plus shipping).  Add 3% for paypal.  Check my Audiogon feedback under mikeg.
Direct coupling of the woofers is used in both speaker designs. The result of Direct Coupling is a response time at least 20x faster than other designs in any loading. Increased speed of this magnitude equates to an overall increase in musicality (i.e. image placement, dynamics, transparency, harmonic fill, timbre, soundstage, and air). Additionally, Direct Coupling extends the upper bandwidth by 2 full octaves and the lower bandwidth by 1.5 octaves (in comparison to sealed or ported alignments).
Pinyon Specs
Design Type: Direct Coupled*
Woofer: 2 x 6.5"
Tweeter: ring radiator, soft-dome
Freq. Response: 34Hz - 50kHz
Amp: 1 - 1000 watts
Sensitivity: 89 dBImpedance:
8 Ohms nominal
shipping weight 108 lbs
Uinta specs
Woofers: 2 x 12"
Freq. Response: 16Hz - 800Hz (50-80Hz recom crossover frequency)Amplifier: 500watts (installed)
Transient Power Rating: 3000watt at 10mSSensitivity:
94 dBSPL @ 10 Watts input:
104 dB cont. (107 dB peak, 1m)SPL @ 100 Watts input:
114 dB cont. (117 dB peak, 1m)SPL @ 500 Watts input:
121 dB cont. (122 dB peak, 1m)
Impedance: 8 Ohms nominal
shipping weight 210 lbs (140 lbs out of the crate)
« Last Edit: 19 Sep 2009, 09:05 am by mikeg1 »
mikeg1
reduced from $6,995 to $5,995.
mikeg1
Reduced:  $5,995 for Pinyons, Hoodooh stands and Uinta sub plus shipping (will sell Pinyons and stands for $3,995 and Uinta sub for $1995 plus shipping).  Add 3% for paypal.  Check my Audiogon feedback under mikeg.
