What kind of enclosure to use for full range speakers?
0 Members and 1 Guest are viewing this topic. Read 4400 times.
acwd1950
Ive got some full range speakers that I would like to make use out of, but I dont know what type of enclosure to build for them. I have been reading that alot of people like transmission line enclosures, is that true? Is there a computer program available to get a starting point on TL enclosures? I have no spec of these driver. Any suggestions on type of enclosures, etc?
Ericus Rex
Re: What kind of enclosure to use for full range speakers?
« Reply #1 on: 28 Aug 2009, 01:17 pm »
The Fostex International site has some recommendations:
http://www.fostexinternational.com/docs/speaker_comp/rec_enc_1.shtml
This should be a good starting point for you.
doorman
« Reply #2 on: 28 Aug 2009, 02:48 pm »
Also check out http://www.planet10-hifi.com/
Depending on what drivers you have of course.
Don
JohnR
« Reply #3 on: 29 Aug 2009, 12:17 am »
Hi, you will need to get the specs of the drivers to do any design, I would think. Otherwise, perhaps just try them on an open baffle and see what happens.
mike j
« Reply #4 on: 29 Aug 2009, 01:50 am »
You'll need to know some of the specs, but here is a good site. I built a pair of these BIBs for some $17.00 full range drivers and was quite pleasantly surprised. :thumb:http://www.zillaspeak.com/bib-howtobuild.asp
Mike
acwd1950
« Reply #5 on: 29 Aug 2009, 12:38 pm »
How would these FR speakers do in a BIB
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-828
I downloaded the calculator zillaspeak.com but I dont have a program to run it. I think its a Excel file extension.
acwd1950
« Reply #6 on: 29 Aug 2009, 12:43 pm »
John,
I thought about using them in a OB. They are some FR out of a old console radio that I got tried of being in the road so I parted it out. So without knowing what brand they are, some of the specs would be hard to come up with. They are 8 inches so they might be ok in a OB
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #7 on: 29 Aug 2009, 06:16 pm »
Can you post some pictures... i have "recycled" many a console and may have seen them.
Consoles are usually just folded OBs, so your 1st opion with most of these is a more modern OB.
dave
acwd1950
« Reply #8 on: 31 Aug 2009, 12:37 pm »
Dave,
I will try and snap some pics tonight and get them posted
acwd1950
« Reply #9 on: 1 Sep 2009, 01:59 am »
Heres pics of one of the drivers that Im wanting to use. On the back of the magnet it says Morse 3.2 ohm
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #10 on: 1 Sep 2009, 02:25 am »
Looks like a midtweeter in an open baffle... It might make 100 Hz...
dave
