XLR input RCA output
0 Members and 1 Guest are viewing this topic. Read 2451 times.
ddriveman
« on: 31 Dec 2003, 07:38 pm »
Can I drive the Bent Audio NOH preamp via the XLR inputs (from my DAC) and have the NOH use the RCA output to drive my tube amps (monoblock LadyDay+ 300B amps). I would like to use the XLR inputs since my DAc has this option but my amps can only accept RCA inputs. Appreciate any inputs
John Chapman
    • http://www.bentaudio.com
« Reply #1 on: 31 Dec 2003, 07:53 pm »
Hello!
This would work fine and is one reason we use transformers rather than autoformers. It makes these conversion issues easy to handle. If you go with multiple inputs then we can include any combination of xlr and rca for inputs and outputs.
Thansk!
John Chapman
www.bentaudio.com
ddriveman
« Reply #2 on: 31 Dec 2003, 07:57 pm »
John,
Thanks for the quick reply
