0 Members and 1 Guest are viewing this topic. Read 5702 times.
The answer to 1) is:use a 9V battery (its terminals fit nicely to speakers' terminals).Put it one way: positive of battery to positive of speaker, the cone should move OUT. Positive of battery to negative of speaker, the speaker should move IN.
I'm just running my RM-40s w/ a single amp, a Earthquake Cinenova 3-channel, 600w / channel @ 4ohms, which has sounded very grainy ever since I hooked up the RM-40s. Anyway, I wound up tuning my pots down to about 11 (mid) and 11:15 (treble) and took out a BUNCH of mortite, wound up being about a 1/2 marble sized chunk for each speaker.It's tricky business tuning these.
I think it has more to do w/the amps' damping ability - an amp w/more damping will require more putty removal, an amp with less damping will require less. Either way, it's a fairly involved process to get it right. After you've done it a few times (you have to re-do it everytime you change anything in your system, including interconnects and speaker wire), you get pretty good at zero-ing on what needs to be done as far as removal/addition.
I think warnerwh has a good start on the subject. The beautiful thing about the putty is you can just stick it back on if you've gone too far - there's zero liability to messing up here (other than starting over).I'd like to add on a little bit to those setup tips - depending on the amplifier/system, the amount of putty that can make the "Ah ha!" change can be anywhere from a fingernail to a small pea. Unfortunately, if you take off too much, you may not be able to hear the difference between "too muc ...
Quote from: AndrikosThe answer to 1) is:use a 9V battery (its terminals fit nicely to speakers' terminals).Put it one way: positive of battery to positive of speaker, the cone should move OUT. Positive of battery to negative of speaker, the speaker should move IN.Great tip! Andrikos, is that safe to do on any speaker? You are talking about the little rectangular 9V batteries, right?Randog
Redbone: Try listening to the midrange for smoothness and richness, this area can definitely become fuzzy if too much is removed and may be easier for you to hear the difference. I suspect after a while you will become more attuned to the subtle changes. The difference between excellence and not near as smooth is only a few fingernails full. Cheers
