balanced "pot in box" with eq or tone controls??
0 Members and 1 Guest are viewing this topic. Read 1530 times.
Jeffr1966
« on: 27 Aug 2009, 08:52 pm »
built into an RM 200 base which would act as a "stand" for an RM200 amp ... this would keep a clean look and a VERY short run of IC's ... can it be done???
this is in keeping with my original RM200 line of questioning.
thx
Jeff
Ericus Rex
Re: balanced "pot in box" with eq or tone controls??
« Reply #1 on: 27 Aug 2009, 11:34 pm »
Huh?   :scratch:
Jeffr1966
« Reply #2 on: 27 Aug 2009, 11:48 pm »
let me try again ... take one of MR's "pot in a box" ideas, use an RM200 chassis for the "pot in a box" enclosure.  add true XLR-inputs and XLR-output to match with the RM200 XLR-in fully balanced design.  Add the tone controls that had been available on the C4 preamp.
the "pot in the box" would then be a perfect size match to the RM200 and could be placed directly underneath the RM200 (no shelf between) - essentially a stand for the RM200.  hopefully this makes sense - makes sense to me but I wrote it.
Jeff
Ericus Rex
« Reply #3 on: 28 Aug 2009, 01:34 pm »
Got it!  That'd be a sweet looking setup.  If Roger'd sell you a chassis (I guess you'd really only need the wood border yes?) the only trick would be this; Since the wood border is curvy, you'd have to recess holes into it for the knobs.  Are you equiped to do that?  And can you have a balanced in/out PASSIVE preamp?  I've never heard of such a thing.  Great idea.  Let us know how it works out.
Jeffr1966
« Reply #4 on: 28 Aug 2009, 02:30 pm »
I have zero talent in the wood working department so I would have to pay someone else to do the "construction".  There are a number of manufacturers that offer balanced passive linestages (Placette, Bent, Reference Line, etc) with or without remote control.  would make for a very cool project IMHO!
