0 Members and 1 Guest are viewing this topic. Read 26551 times.
Here is my take. They are flat and lifeless with most "affordable" tube amps. They also have zero dynamic capability with anything less than 50 watts RMS per side. On a budget, you can get a taste for Maggie sound using NAD amps. The 50 watt per channel amps they make sound great on Maggies. Their bigger amps are not so good to my ears.While I'm rambling on about Maggies - DO NOT try to absorb the back wave from them. They are planar dipoles and you'll kill the magic of the dipole "larger than life" sound. At the most, set some bushy plants in the corners but not directly behind the speakers. Setup your room with a "live front" and absorb at the rear behind your listening position. There is no need for side wall treatment unless you have significant ringing. Get a thick carpet to dampen floor to ceiling reflection.If you are talking MMG's - smallish rooms are best. 12 x 14 x 8 or so. Increasing the room size makes it hard to get high volume without going to a larger Maggie. Subs - get a sealed box sub good down to 25Hz or so. Don't put it in the corner, rather somewhere in the center between the speakers but back towards the front wall. Cross over around 70 - 80 Hz (MMG is good down to 60Hz in theory, but resonates at 100Hz, causing a sharp-sounding rolloff below 100Hz.Seating - don't try to listen nearfield. These are not point source speakers. 8' minimum.Tilt - your taste - vertical is brightest at the listening position. Toe-in - 1" towards seating. Tweeters - outside. Separation - 6' - 8'. Symmetrical placement is critical side-to-side and front-to-back.Enough for now... Point is that placement is almost more important than the amp or source...
I have owned about 5 pairs of Maggies. Here is my take. They are flat and lifeless with most "affordable" tube amps. They also have zero dynamic capability with anything less than 50 watts RMS per side. I have used them with tube amps from 20 watts per side up to 100 watts per side. None were adequate. The best sounding was the little Jolida EL84 amp, but only for late night at low volume. Second best was the Cayin TA-30, third the Vista i34, but only marginally more drive capability. The worst were the TAD-1000 monos. Note that these were all budget amps, not ARC or suchlike. With solid state amps they tend to be bright, but easier to drive. Pairing a bright solid state amp with a darkish tube preamp works wonders but can introduce some slowness that kind of defeats the Maggie speed.On a budget, you can get a taste for Maggie sound using NAD amps. The 50 watt per channel amps they make sound great on Maggies. Their bigger amps are not so good to my ears.My latest opinion (as this is a subjective hobby) is that they would sound incredible with the ClassDaudio SDS-254 or SDS-258. I have built the CDA-254 and SDS-254 and found the SDS-254 to be the better choice as it can be run passive (no preamp) and sounds smooth - not a hint of brightness - kind of like a big MacIntosh amp. This amp has me wanting to buy Maggies again as I think it would be a match made in heaven. 250 watts per side. But get the upgraded power supply board as the 4 ohm load will punish the reserves in the low profile PSU.My suggestion: Class D amps, passive preamp, the best digital source you can afford. Oh, and space to place the speakers correctly.While I'm rambling on about Maggies - DO NOT try to absorb the back wave from them. They are planar dipoles and you'll kill the magic of the dipole "larger than life" sound. At the most, set some bushy plants in the corners but not directly behind the speakers. Setup your room with a "live front" and absorb at the rear behind your listening position. There is no need for side wall treatment unless you have significant ringing. Get a thick carpet to dampen floor to ceiling reflection.If you are talking MMG's - smallish rooms are best. 12 x 14 x 8 or so. Increasing the room size makes it hard to get high volume without going to a larger Maggie. Subs - get a sealed box sub good down to 25Hz or so. Don't put it in the corner, rather somewhere in the center between the speakers but back towards the front wall. Cross over around 70 - 80 Hz (MMG is good down to 60Hz in theory, but resonates at 100Hz, causing a sharp-sounding rolloff below 100Hz.Seating - don't try to listen nearfield. These are not point source speakers. 8' minimum.Tilt - your taste - vertical is brightest at the listening position. Toe-in - 1" towards seating. Tweeters - outside. Separation - 6' - 8'. Symmetrical placement is critical side-to-side and front-to-back.Enough for now... Point is that placement is almost more important than the amp or source...
If your considering SS either Classe or Plinius. Tubes AR Classic 60.
