Driver glue advice needed
0 Members and 1 Guest are viewing this topic. Read 1085 times.
scottpretti
« on: 31 Dec 2003, 04:23 pm »
I have a small spot on a driver that is peeling up, about half an inch.  What is the best glue to affix a rubber surround to the metal speaker frame?  I was thinking of using a small amount of black silicone between the frame and surround, will that harm the thin rubber surround?
Any good sources for a glue to do this?
mgalusha
« Reply #1 on: 31 Dec 2003, 05:16 pm »
I've used rubber cement in the past for this. I think Parts Express sells special speaker adhesive.
Good luck!
mike g
