I actually did notice a slight red hue through the green on the LED at startup, it was there but very faint. I'm not concerned as the unit sounds fine so far and my voltages were pretty close to spec. I'm going to check voltages again today and see if anything varies from my initial check.
Another question, will changing the rectifier create any changes in voltages? I know some tubes like a little higher voltage, I came in at 5.7 volts with the JJ GZ34 after having problem with the 5Y3 EH I originally installed. I then popped in a Sylvania 5V4GA that was in my original Cornet. Not sure I like how that sounds, a little too much in the low end for my tastes but I also swapped in a 5814 in the AU7 spot, could be that tube. And yes, this unit has a lot of break-in to go, only about 4 hours on it yet.
The other tubes I'm going to try, I have a couple 5751's on hand, am waiting on a couple RCA longplate, a RCA 12AU7 cleartop and the 6106 as well.
I wish I had a tube tester. I have some vintage Mullard and Tele 12AX7's but I know at least a couple of those crackled in my other Cornet.
I'll also try to post a few pics in the next day or two as well. Lots of upgrades in the capacitors thanks to suggestions from tubesforever.
Brian
Brian
